Discourse’u sunucuma kuruyorum. Kurulum sırasında bir hata görmüyorum. Ama siteme girmeye çalıştığımda tarayıcıda;
Bu sayfa çalışmıyor
hatası yada
Cloudflare’in Error 521 sayfasını alıyorum.
./launcher logs app çıktısı şu şekildedir:
run-parts: executing /etc/runit/1.d/00-ensure-links
run-parts: executing /etc/runit/1.d/00-fix-var-logs
run-parts: executing /etc/runit/1.d/01-cleanup-web-pids
run-parts: executing /etc/runit/1.d/anacron
run-parts: executing /etc/runit/1.d/cleanup-pids
Cleaning stale PID files
run-parts: executing /etc/runit/1.d/copy-env
run-parts: executing /etc/runit/1.d/letsencrypt
[Sun 09 May 2021 09:32:15 AM UTC] Domains not changed.
[Sun 09 May 2021 09:32:15 AM UTC] Skip, Next renewal time is: Thu 08 Jul 2021 09:17:49 AM UTC
[Sun 09 May 2021 09:32:15 AM UTC] Add '--force' to force to renew.
[Sun 09 May 2021 09:32:15 AM UTC] Installing key to:/shared/ssl/dursuncan.com.key
[Sun 09 May 2021 09:32:15 AM UTC] Installing full chain to:/shared/ssl/dursuncan.com.cer
[Sun 09 May 2021 09:32:15 AM UTC] Run reload cmd: sv reload nginx
warning: nginx: unable to open supervise/ok: file does not exist
[Sun 09 May 2021 09:32:15 AM UTC] Reload error for :
[Sun 09 May 2021 09:32:16 AM UTC] Domains not changed.
[Sun 09 May 2021 09:32:16 AM UTC] Skip, Next renewal time is: Thu 08 Jul 2021 09:17:57 AM UTC
[Sun 09 May 2021 09:32:16 AM UTC] Add '--force' to force to renew.
[Sun 09 May 2021 09:32:17 AM UTC] Installing key to:/shared/ssl/dursuncan.com_ecc.key
[Sun 09 May 2021 09:32:17 AM UTC] Installing full chain to:/shared/ssl/dursuncan.com_ecc.cer
[Sun 09 May 2021 09:32:17 AM UTC] Run reload cmd: sv reload nginx
[Sun 09 May 2021 09:32:17 AM UTC] Reload error for :
Started runsvdir, PID is 662
ok: run: redis: (pid 674) 0s
ok: run: postgres: (pid 670) 0s
chgrp: invalid group: ‘syslog’
