Merhaba;
loadbalans sunucuda bu hatayı alıyorum çözemedim desteğinizi rica ederim
Last login: Sat Mar 4 14:27:57 2023
root@localhost:~# tail -f /var/log/jitsi/jvb.log
at org.jivesoftware.smack.tcp.XMPPTCPConnection.connectInternal(XMPPTCPConnection.java:849)
at org.jivesoftware.smack.AbstractXMPPConnection.connect(AbstractXMPPConnection.java:526)
at org.jitsi.xmpp.mucclient.MucClient.lambda$getConnectAndLoginCallable$9(MucClient.java:627)
at org.jitsi.retry.RetryStrategy$TaskRunner.run(RetryStrategy.java:167)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:829)
JVB 2023-03-04 14:32:44.518 WARNING: [25] [hostname=kolayvk.domainname.com id=shard] MucClient.setPresenceExtensions#459: Cannot set presence extension: not connected.
